2011년 10월 24일 출시 / 2.2, 2.4, 또는 2.5 GHz 쿼드-코어 Intel Core i7 프로세서
355 질문 전체 보기
Logic board has dicloleration (reddish) on the underside of the Intel chip
Here's what I'm talking about 2417 I-7 core to duo
Charger connects light on and no start up, no power, only blinking battery indicator lights......
Is this a overheated logic board????
Thanks for the info everyone!!!
해당 질문 답변하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글:
@talmadge , Talmadge Dowse, Smell the chip/board, if it smell burnt/weird it is probably bad.
의 답변
No burned smell, someone didn't exactly know how to take apart the battery connector was half ripped up and the track pad was not in level etc....It was part of a donation from a friend that owned a hauling clean up service
의 답변
Its probably going to need a new board
의 답변
@talmadge as @lpfaff1 is suggesting, it sounds like someone has reflowed the chip, so it was likely experiencing the common GPU issues on the 15" 2011 models.
Just replace it with a 2012 board to be honest, no point wasting any time trying to fix this one.
의 답변
2에 댓글 더 나타내기
의견 추가하세요
아이폰 배터리 수리 키트
Only $29.99
Buy Now
아이폰 배터리 수리 키트
Only $29.99
Buy Now
1개의 답변
That sounds like a battery needs replaced or the volt regulator or capacitor or some sort of electronic part needs replaced.
해당 답변은 도움이 되었습니까?
점수 0
댓글:
Thank you for this info.
Im appreciative, these Logic Boards are prone to video chip problems as well, So I might just upgrade to a 2012 model Logic Board since its the same btw
Thanks very much!!
의 답변
의견 추가하세요
귀하의 답변을 추가하십시오
Talmadge Dowse 가/이 대단히 고마워 할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 59
