MacBook Pro 13" Retina Display, 모델 A1502의 2015년 3월 업데이트는 5세대 Intel Core i5 및 i7 프로세서를 포함하며 Force Touch 트랙 패드를 소개합니다.
525 질문 전체 보기
System failure, cant boot from SSD, data recovery
Hi guys,
A customer brought an mac pro 13" early 2015 modell.
The macbook can not boot, we tried boot from usb drive, and check the ssd with disk utility, but we got error 8 in the first aid.
after we connected an external hard drive with other osx (yosemite) in usb port, and the macbook booted properly. We check ssd drive, we see any folders, but when we enter the users folder, the folder is empty.
Users folder has most important files for our costumer.
Pls give me advice what a problem, that we could not see this folder's content.
Thank you
Tibor
답변되었습니다! View the answer 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
의견 추가하세요
US$100 이상 또는 Pro Tech Toolkit을 포함한 모든 주문의 배송은 무료입니다!
상점 둘러보기
1개의 답변
선택된 해법
You will need to pull the stick and put it in an external enclosure sure as the :
OWC Envoy Pro
Portable, Bus-Powered USB 3.0 Enclosure
For Apple Flash SSDs (June 2013-Current Mac Models)
https://eshop.macsales.com/item/OWC/MAU3...
해당 답변은 도움이 되었습니까?
점수 3
댓글:
Thank you, I'm thinking about, but the problem solving is urgent :( why can not see the users folder's contents, when the other folders readable (system etc.)
의 답변
Get a complete history on the machine. Have the LSI been tripped? If you have another 2013-2016 machine around try the stick in it.
의 답변
의견 추가하세요
귀하의 답변을 추가하십시오
Iphone Service Szeged 가/이 대단히 고마워 할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 1
지난 30일: 5
전체 시간: 494
