Released on September 19, 2014, this 4.7" screen iPhone is the smaller version of the iPhone 6 Plus. Identifiable by the model numbers A1549, A1586, and A1589.
4564 질문 전체 보기
Black screen with grey Stripes!
My phone all of a sudden started to show this screen in the pic! I tried to reset the device but it didn't help!
Does anybody have an idea about what is going on ??
Update: Screen was replaced but I still have the same issue!!
답변되었습니다! View the answer 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
의견 추가하세요
US$100.00 이상 또는 Pro Tech Toolkit을 포함한 모든 주문의 배송은 무료입니다!
상점 둘러보기
Ever fixed something? That’s Genius.
Share your repair story with #ImAGenius
We Are All Geniuses
3개의 답변
선택된 해법
@dasan is right. Something caused this to happen. Phones don't break all by themselves. It technically can happen, but this would not be the result. If the display connectors aren't placed properly I could see this happening, also this looks like damage to the display. I would recommend reseating the connections using this guide
iPhone 6 Screen Replacement
If that doesn't take, I would recommend using this display, you could save some loot, buying it somewheres else, but you'll likely yield bad results. Part doesn't work, then how to exchange? You can't
iPhone 6 Screen
@dasan. This is not personal. I'm trying to reward you. Learn English better, yes you're right we should be learning your language better. But, I'm sorry, that will never happen. Why I can't say. Thank you for helping. You sound like a good repair technician. Keep helping here! Please! We would love to have you helping in the community! Together we are strong! I know you have information we don't. This site is for sharing information and fixing answers, so we can help! It is a thankless job, which I'm working on that part
Man, I'm just tryin to have a scotch and check my order status...
iPhone 6 Screen 이미지
상품
iPhone 6 Screen
$64.99
해당 답변은 도움이 되었습니까?
점수 2
댓글:
So your telling my english is bad ok no issues i can correct it
의 답변
의견 추가하세요
가장 유용한 답변
Can you tell me the device had fall? try to refixed the display once, if not it is fallen then the display is got damaged inside and needed to replace.
해당 답변은 도움이 되었습니까?
점수 3
댓글:
No it didn't fall! I was just using the device and suddenly the screen was frozen ! I tried to reset with power and home button but it didn't work!
의 답변
Ok pls check with new display fixing and try this faulty display in other iphone 6 device and let me know
의 답변
I did !! still have the same problem!
의 답변
의견 추가하세요
UP UP UP UP UP Up UP UP UP UP
해당 답변은 도움이 되었습니까?
점수 0
의견 추가하세요
귀하의 답변을 추가하십시오
Felipe Wilson 가/이 대단히 고마워 할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 26
지난 30일: 141
전체 시간: 1,973
