주요 콘텐츠로 건너뛰기
Repair guides and support for the laptop/tablet hybrid in the Toshiba Satellite Radius series released in 2014.
48 질문 전체 보기
Broken Ribbon Cable Clip on Backing
Hey Guys !
So upon looking to figure out what was wrong with my keyboard/power I discovered the ribbon cable connector on the back part of my laptop was off ! What do I do ?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
There are a couple of styles of connectors for keyboards, one is the Zero Insertions Force (ZIF) that has a bail. which may be missing if the ribbon cable came loose on its own. The other style is the Low Insertion Force (LIF) that you just carefully push the ribbon cable in and make sure that the cable is inserted evenly.
If the connector is a ZIF connector and the bail is missing then try holding the ribbon cable by inserting a piece of thin card stock into the connector on the opposite side of the contacts. Use a piece of tape to hold the card stock in place.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Samantha Richter 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 2
전체 시간: 791
