주요 콘텐츠로 건너뛰기
The GoPro Hero5 Black is an HD waterproof action camera released by GoPro in October of 2016. The 4k resolution video camera has voice control, a touch screen display, and built in WiFi.
82 질문 전체 보기
Why is my GoPro Hero 5 keeps on hang, can't review the pictures?
Why is my GoPro Hero 5 keeps on hang, can't review the pictures even if I have it connect on my Phone, still displays on "Loading" only until it is batter empty.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개
Tried to hold on ti MENU but nothing happened. If only I can send video here....
댓글 달기
답변 4개
선택된 해법
If your camera is currently frozen, try to reset the camera by holding the MODE button for 10 seconds (hold the top SHUTTER button on the HERO Session / HERO4 Session).
Should the camera not prompt a reset, remove and then reinsert the battery to get it unstuck (for cameras with integrated batteries, Step 1 will imitate a battery pull).
Make sure you have the most current software on your camera.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
가장 유용한 답변
Hello,
I used to have the same problem and I solved by changing the micro SD card.
I had a Samsung one that was giving me lots of issues.
I hope it helps.
Regards
Ricardo
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
Thank you! It will help. I will try your suggestion cause the sd card given to me was also Samsung. Thank you again
댓글 달기
Still, not prompt a reset. Even if its connected to phone to view the pictures easy. We need to remove the bat just to reset it or turn it off.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
That sucks though. Is there some simple troubleshooting or tricks to fix this? Im sure their support will have something to say about the issue. Before buying an action camera, I make sure they have good support.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Jenina Artus 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 19
전체 시간: 9,511
