Why is my GoPro Hero 5 keeps on hang, can't review the pictures?
Why is my GoPro Hero 5 keeps on hang, can't review the pictures even if I have it connect on my Phone, still displays on "Loading" only until it is batter empty.
좋은 질문 입니까?
좋은 질문 입니까?
If your camera is currently frozen, try to reset the camera by holding the MODE button for 10 seconds (hold the top SHUTTER button on the HERO Session / HERO4 Session).
Should the camera not prompt a reset, remove and then reinsert the battery to get it unstuck (for cameras with integrated batteries, Step 1 will imitate a battery pull).
Make sure you have the most current software on your camera.
해당 답변은 도움이 되었습니까?
Hello,
I used to have the same problem and I solved by changing the micro SD card.
I had a Samsung one that was giving me lots of issues.
I hope it helps.
Regards
Ricardo
해당 답변은 도움이 되었습니까?
Thank you! It will help. I will try your suggestion cause the sd card given to me was also Samsung. Thank you again
Still, not prompt a reset. Even if its connected to phone to view the pictures easy. We need to remove the bat just to reset it or turn it off.
해당 답변은 도움이 되었습니까?
That sucks though. Is there some simple troubleshooting or tricks to fix this? Im sure their support will have something to say about the issue. Before buying an action camera, I make sure they have good support.
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 8
30일 전: 21
전체 시간: 9,702
댓글 1개
Tried to hold on ti MENU but nothing happened. If only I can send video here....
Jenina Artus 의
