Osciation knob problem, always oscillating
Fan is oscillating always and not able to stop oscillating,when the knob is pushed down or pushed up. Oscillating knob is on the top of the motor. Can you please advice on this?
좋은 질문 입니까?
좋은 질문 입니까?
vishnugj , It sounds like the knob/control has either detached or broke. Check that the control knob attaching screw is snug. If under warranty return for repair,replacement/refund. If not under warranty, you can try disassembling the fan to see what the problem with the oscillating control is and possibly repair. Parts may not be available so you may have to epoxy parts back together or get inventive to repair. For replacement parts you can try contacting the manufacturer. I posted a couple video links that may help(not your model) in disassembly. Good luck.
해당 답변은 도움이 되었습니까?
24 시간 전: 10
7일 전: 44
30일 전: 131
전체 시간: 16,700
댓글 1개
how do you remove the Oscillation knob from a Lasko 3016 fan
Frank Whalen 의
