주요 콘텐츠로 건너뛰기
모델 번호 A1238 / 80, 120, 또는160GB 하드 드라이브 / 검정색 또는 은색 금속 외형
903 질문 전체 보기
"HOLD" button issues - Sprite contamination
The end of my iPod that houses the HOLD button was accidentally dipped into Sprite a few years ago. Since then, the HOLD button has been getting progressively worse. I think it just needs to be cleaned. What tools do I need to buy and which repair guide to I need to follow to do this?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
stevemoody after a few years of contamination it is unlikely that cleaning it will work. You are probably looking at a lot of corrosion. At minimum, replace the headphone jack/hold switch and clean your iPod with some high grade isopropyl alcohol. Use this guide for the repair and the part is available at places like this. Your iPod came in two flavors, thick and thin. Make sure you get the right cable.
iPod Classic (Thin) Headphone Jack & Hold Switch 이미지
상품
$9.99
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
귀하의 답변을 추가하세요
stevemoody 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 54
