이 토론글을 스크롤하여 댓글을 달 적절한 위치를 찾으세요. 그런 다음 "이 게시글에 댓글 달기"를 클릭하여 댓글을 이동하세요.
댓글 1개:
Hi,
What is the model number of your laptop?
It seems as though it is failing to start and that it is giving "error beeps". You need to count the beeps and also determine if there is a sequence to them and if they are long or short beeps, e.g. does it go 4 beeps - pause - 4 beeps - pause or perhaps 2 beeps - pause - 2 beeps or 2 beeps -pause 1 beep - pause 2 beeps -pause 1 beep or even 1 short beep 1 long beep 1 short beep etc if you get what I am saying
Knowing this will help to determine the cause of the problem.
Hi,
jayeff 의
