ps4 signal turns on with no signal on tv.
my ps4 turns on but shows no signal on the tv.please how do i fix that?
좋은 질문 입니까?
좋은 질문 입니까?
I'm assuming that you've checked the HDMI cable and tried another cable. If that's the case then the most likely cause of this problem is a faulty HDMI port. This is something that most people don't have the skill to replace but you can check out my video to see if it's something you can do or not:
해당 답변은 도움이 되었습니까?
I can't do all of that!!!
i cant do that im only 12 years old
Same bro like who do you think I am
I did all of that and put my PS4 back together.Then I pluggedd my hdmi in to test it out it still read no signal.What do I do?
해당 답변은 도움이 되었습니까?
Are you 100% sure you soldered the HDMI port on correctly...including the 19 small pins?
In this case it’s actually not my hdmi port cus I use the same port for my DStv decoder and it’s show on my tv but it says no signal any time I connect my ps 4
im sad i want be able to play fortnite. cuz my tv keeps saying no signal
해당 답변은 도움이 되었습니까?
24 시간 전: 4
7일 전: 34
30일 전: 193
전체 시간: 50,338
댓글 1개
Hi sir how to fix a PS4 that appear 576p but no display after a second
Teraoi Teira 의
