메인 콘텐츠로 스킵하기
Computer screen goes blank, and if sound is on it plays white noise
At first I thought it was an overheating issue, but it happens pretty much right away sometimes, with the laptop almost stone cold. It only seems to happen if I attempt to multi-task, as in have a browser open while listening to music etc. And as I said, if sound is playing it becomes just white noise, fuzzy. If theres nothing playing then it remains quiet. The screen goes black, but is still lit up. The only way I've found to stop it is to turn the laptop off and on again by holding the power button, but it's incredibly annoying as I lose anything I have open at the time, so I'm hoping maybe there's an solution to this without having to replace it.
답변되었습니다! View the answer 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
의견 추가하세요
1개의 답변
선택된 해법
Is the fan running when it shuts down? If theres no fan it will shut down on its own even if its not hot . Is the GPU a Radeon or Nvidia? Just a couple things to try , pull the memory out and run it one stick at a time and try it in different slots . Could be a memory issue .You can also check the event viewer and see if it sheds any light on your problem.
해당 답변은 도움이 되었습니까?
점수 2
의견 추가하세요
귀하의 답변을 추가하십시오
Erical 가/이 대단히 고마워 할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 69
