2.3L 4cyl or 3.0L V6, 6th Generation
366 질문 전체 보기
Clutch not engaging hydrolic fuel levels are fine but clutch doesn't
I hit the panel to the floor no tension at all
Thelse hydronic dot 4 level are fine. It just would not engadue. Last night was fine today not.
해당 질문 답변하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
의견 추가하세요
US$100 이상 또는 Pro Tech Toolkit을 포함한 모든 주문의 배송은 무료입니다!
상점 둘러보기
1개의 답변
가장 유용한 답변
Tallat Mahmud , There may be a leak in the hydraulic clutch line, look under the hood and under the car to see if fluid leak evident and look at the lines and connections for leaks, if no leak observed probably a faulty/bad clutch master cylinder or slave cylinder(seals leaking internally) and has let air into the system. Below are links that will show or tell how to replace master and slave cylinder. Note the picture is of the slave cylinder, I have seen a few of these break at the bolt flange and then they swivel/turn and then the pin will no longer contact the fork, in this case the cylinder will have to be replaced also. Good luck.
https://www.youtube.com/watch?v=vOiHgP33...
http://honda-tech.com/forums/acura-integ...
해당 답변은 도움이 되었습니까?
점수 1
의견 추가하세요
귀하의 답변을 추가하십시오
Tallat Mahmud 가/이 대단히 고마워 할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 14
전체 시간: 203
