iPhone 7 home buttun wont work
why my iphone 7 home button wont work after replace battry?
좋은 질문 입니까?
좋은 질문 입니까?
Did you remove the ribbon cable, found in [잘못된 안내서 링크] and if so have you made sure you reattached it correctly?
해당 답변은 도움이 되었습니까?
Do a restore, if that does not work the phone is dead, only Apple can fix it.
해당 답변은 도움이 되었습니까?
you probably broke the home button extension cable when disassembling. It doesn't take much to rip this fragile cable.
Check to see if its ripped. If so you'll need to replace the backlight film (includes 3d touch, and home button extension cable)
해당 답변은 도움이 되었습니까?
have you turned the phone off before doing the disassembly work? this blog shows some reasons why home button not working https://www.etradesupply.com/blog/why-to...
해당 답변은 도움이 되었습니까?
Watch this Video for more Information about the iPhone 7 Homebutton:
If you broke the home button extension cable you'll need to replace the backlight. Like in this Video:
https://youtu.be/W1sQ0cl1oYc (German Version)
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 239
