주요 콘텐츠로 건너뛰기
Released April 2013, model numbers GT-N5100 (3G & Wifi), GT-N5110 (Wifi), and GT-N5120 (3G, 4G/LTE & Wifi)
20 질문 전체 보기
Why won't my tablet read my SD card
My samsung tablet is not reading the SD card. Music and photo apps freeze up and do not display what is on the SD card. Is there is a fix for this. I have already tried two different SD cards.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 3
댓글 1개
Did you format the card in the tablet prior to using?
댓글 달기
답변 4개
가장 유용한 답변
Is the SD card recognized on a computer and is it formatted with FAT32? Make sure it is formatted and if you are absolutely sure it is go inot storage settings in settings and see if the SD card is recognized there. if it is, just click format sd card and then it should work fine. If not check the pins inside the sd card slot and see if they are all straight and aligned. If not then it would require soldering and a new sd card reader to fix it. If they are then i honestly have no clue what it would be. maybe @oldturkey03 or @mayer knows?
이 답변이 도움이 되었나요?
점수 2
댓글 1개:
My apps turn grey with the android logo eveytime i put it in my sd cadd im usih a samsaung galaxy tab a 2016
댓글 달기
Sorry dear ... I posted how to fix your tablet but? Because I included a link as to where to find the part you need? They marked my reply as spam. Apparently this site is run by morons. Long & short of it? NO you do NOT need to solder anything!
Do a search on youtube (again, sorry, I am not allowed to include the link) ... there are several videos on how to do this. And your sd card reader is paired with the vibration moter. You can order one off of ebay. Just look for a company with a high rating. Again? Sorry but? This site does not allow me to provide a link to help you. ...
Whsts the sense of having a help forum if you cannot provide people with the tools they need yo be helped? Aye "ifixit"?! .... unreal
이 답변이 도움이 되었나요?
점수 0
댓글 달기
If you accidentally stuck your sd card in the slot without the tray, and have to pry it out with thin items, like a bobby pin, a hair pin, or even a key latch.
When you have successfully got the card out and insert it properly, if it does not read on the Samsung tablet, could it be that the inside of the slot has been scratched up and it cannot read the card? Help me please!
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Your SD Card Reader is bad on your logic board the only fix is to solder a new one on and that is near impossible as its done by machinery in the factory.
Stephen T.
이 답변이 도움이 되었나요?
점수 -1
댓글 1개:
It may be something a lot easier to fix, like a software issue or a formatting issue.
댓글 달기
답변을 추가하세요
Gayle Caya 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 5
지난 7일: 18
지난 30일: 53
전체 시간: 6,464
