Ipad will not turn on after replaced digitizer
Hey! Now I just replaced the digitizer and was finishing up when I realized I should to check that the iPad turns on. It doesn't and I have tried plugging the iPad into my macbook but it does not recognize that there is anything plugged in. Any suggestion?
좋은 질문 입니까?
댓글 7개
I may have not turned off my iPad and so it might be dead D: if so is there anyway that I can fix it?\
Cameron Parker 의
Hold down power and home button until the iPad comes on, if it doesn't come on after about 20 seconds, try leaning it on charge for a good while.
rayeasom 의
Did you unplug the battery when doing this? If you did, did you use a metal or plastic spudger
Cameron 의
Cameron, I may have not unplugged the battery.
Cameron Parker 의
If you didnt, you probably shorted something in which case your iPads done. Try putting the old digitizer in and see if it works
Cameron 의
댓글 2개 더보기
