모델 A1418 / Late 2012 / 2.7 & 2.9 GHz Core i5 또는 3.1 GHz Core i7 프로세서
154 질문 전체 보기
iMac won't boot. HD and FAN are spinning for 1 sec
Hi, When I power on my iMac I hear the HD and Fan spinning for 1 second. Then it stops and does the same thing over and over. 1 LED is steady the second LED lights up when the fan and HD start spinning. See pictures. What could be the problem? If the power supply would be damaged there shouldn't be power, LED or spinning HD and fan right (even when it's just for a second right?)
해당 질문 답변하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
의견 추가하세요
US$100 이상 또는 Pro Tech Toolkit을 포함한 모든 주문의 배송은 무료입니다!
상점 둘러보기
1개의 답변
가장 유용한 답변
Here's a breakdown of what the diagnostic LED mean: Diagnostic LED's
From the sounds of it you have a logic board issue with the power regulator logic.
Do you have your system plugged into a surge suppressor or UPS? If not, you may want to get one, its even possible the suppressor is shot as over time it does lose its effectiveness.
해당 답변은 도움이 되었습니까?
점수 1
댓글:
I've ordered a new power supply. Keep you posted.
의 답변
Replacing the power supply didn't solve a thing...
의 답변
I thought not, sadly this is a logic board issue as the regulators are there.
의 답변
What exactly do i have to change on the logic board?
의 답변
의견 추가하세요
귀하의 답변을 추가하십시오
Mattis 가/이 대단히 고마워 할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 2
전체 시간: 142
