주요 콘텐츠로 건너뛰기
2015년 9월 25일 출시. Model A1688/A1633. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 6, 64, 또는 128GB / 은색, 금색, 스페이스 그레이 및 로즈 골드로 제공하였습니다.
2690 질문 전체 보기
Why is my iPhone 6S won't keep on
After having a water-damaged, I went to the apple service, they cleaned the main board with special liquid, my phone can work again. After a week, my phone suddenly turned off, I charged it two days later and its working. Same thing happened again. I wonder if I should changed the battery because it is 60% when it went off, but it has no power when I try to charge it? I try to plug it in charging right away but it won't turn on, I have to wait at least a day after.
Or is it about the LCD cause the screen went blur before the phone turned off?
Your answer / help would mean so much to me, thank you in advance.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 4개
선택된 답변
I'm surprised apple would even offer that. If they did not replace the battery then most likely the battery got affected from the liquid damage.
해당 답변은 도움이 되었습니까?
점수 4
댓글 달기
Hmm Apple Stores don't do water damage repair in house, they only do basic repairs, or swaps. Was this an Apple Store? Or an independent shop?
Either way, in my experience once you get liquid in the device you are better off using your money towards a replacement, as opposed to trying to get it repaired. Even after you clean a water damaged board it may (and probably will) continue to have issues down the line. You will end up spending more in the long run. Since it is able to boot at the moment I would do a full backup and go through either your insurance, apple directly, or an online vendor to get a replacement
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Sounds more like the Pmic chip Having contamination under the chip rust will cause many issues.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
If you aren't expert in testing cables u need to take it to an expert so he can test cables and ic's of ur phone
해당 답변은 도움이 되었습니까?
점수 -1
댓글 2개:
You can't test individual ics on the board without taking the them off so what's the point?
there is a way by a flash which is connected at the same time with the motherboard to a computer and it will directly give u where is the problem on the board
댓글 달기
귀하의 답변을 추가하세요
raechalista 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 2
전체 시간: 117
