메인 콘텐츠로 스킵하기
2016년 9월 16일 출시. Model 1660, 1778. GSM 또는 CDMA / 32, 128 또는 256 GB / 로즈 골드, 금색, 은색, 검정색, 칠흑색으로 제공됩니다.
1198 질문 전체 보기
Camera image shifts and will not focus in certain camera modes
After successfully replacing the aluminum body with an aftermarket one on my 7+, I tried the same thing with an iPhone 7 however I have come across a strange camera issue. This issue is evident in Panoramic and Time Lapse modes while in any other mode isn't present. The image on the phone is most shaky and distort when you first switch to the mode, and then it evens out a bit but keeps noticeably shaking even when the phone is itself unmoving making it difficult for the phone to focus. I suspect this has something to do with the optical image stabilization but really I don't know. I was wondering if any of you have any ideas what could be causing this or if you've experienced the issue yourself.
해당 질문 답변하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글:
have you restarted the iPhone ?
의 답변
의견 추가하세요
1개의 답변
가장 유용한 답변
You need to replace the foam insert around the camera. Sounds like the lens can't move in and out.
해당 답변은 도움이 되었습니까?
점수 1
의견 추가하세요
귀하의 답변을 추가하십시오
Mark Dunnam 가/이 대단히 고마워 할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 1
전체 시간: 40
