주요 콘텐츠로 건너뛰기
기기를 수리하세요
수리할 권리
상점
2015년 3월에 발표, 2015년 4월 10일에 출시된 Galaxy S6은 Galaxy 라인의 다음 주력 제품입니다. 곡선형 스크린 버전은 Galaxy S6 Edge로 알려져 있습니다.
493 질문 전체 보기
My internal memory chip
Is there any way I can get my stuff off of my internal memory chip and place it on a sd card? My phone will not turn on nor will it charge. When the battery was replaced the phone got hot when it was connected to a charger to charge.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글:
Maybe the charging port is the issue? Perhaps the contact is loose and a lot of heat gets produced when all the charging current must go through a small area.
의견 추가하세요
답변 1개
선택된 해법
@ee_major you can only get files off your phone if you get your phone to start up. You cannot retrieve anything from a dead board since the memory is a soldered part of the motherboard and cannot simply be placed onto another board.
해당 답변은 도움이 되었습니까?
점수 5
댓글:
So when the board is dead, the chip is dead? Is it possible to remove the chip and put it on a working board to get the info off of it?
Since full disk encryption is mandatory on Android 6.0 and above, it is not likely you get any readable info either a chip-off or replacing it on to another board. The chip itself is a BGA95 style chip and would require you to have the right tools and some really good skills to accomplish the transplant. If the data is very vital to you I recommend you try one of the many data recovery companies out there.
의견 추가하세요
귀하의 답변을 추가하십시오
Zakia Gregory 가/이 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 19
전체 시간: 4,271
