Suddenly its stop working. Not even getting start
Some how when i got up and push the power key its not working . i tried to charge it . i tried to remove bettery and fix it back but still there no movement . please please help
좋은 질문 입니까?
좋은 질문 입니까?
danidisha , Try a different compatible charger for a couple hours and try. Check charging port, and battery contacts are not damaged, remove any debris/corrosion, clean and inspect the gold contacts on both the battery and on your phone. If known good charger and port looks good/clean/undamaged/not loose the battery can be tested with a DVOM and does not show charged up, the battery is most likely faulty.
Try a force restart, Press and hold the Power key for 30 seconds, If the phone starts to power on, release the Power key.
Still no go, you may have to do a factory reset,(full instructions at link below). Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 68
