메인 콘텐츠로 스킵하기
모델 A1369, 1.6, 1.7, or 1.8 GHz 프로세서, 64, 128 또는 256GB 플래시 저장공간
321 질문 전체 보기
Plugging MacBook Pro display onto MacBook Air
As a temporary replacement, can I plug a MacBook Pro 13" mid 2009's display assembly onto my 13" mid 2011 MacBook air's motherboard ?
It is ok if it cannot close, or is not transportable. All I need is to be able to troubleshoot my MacBook Air.
I am wondering :
1) whether it will work
2) whether it can damage either the display or the laptop
Thank you in advance for your help
답변되었습니다! View the answer 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
의견 추가하세요
맥북 배터리 수리 키트
기본 가격은 $69.99
Buy Now
맥북 배터리 수리 키트
기본 가격은 $69.99
Buy Now
1개의 답변
선택된 해법
Sorry No
Apple transitioned the display systems from LVDS signaling to iDP (think how we migrated our TV's from analog to digital to get better resolution in our content). The signals are not pin compatible and will in fact damage things! A better approach here is to use an external display.
How about telling us what happened with your system, maybe we can offer you some guidance here.
해당 답변은 도움이 되었습니까?
점수 3
댓글:
Thanks for the swift answer ! I thought my MacBook Air also used LvDS. Are you sure apple had already transitioned by that time ?
의 답변
Can you tell us what happened or what you see on the display now?
의 답변
@danj initially screen was flickering. I opened it, and tried to unplug it and stuff. Since then it is pitch black. I am almost sure that at some point I plugged the backlight cable the wrong way. Other people seem to have blown their backlight fuse when doing that. So I guess that is my problem as well. However, in order to test that I am thinking of plugging another screen on my laptop, see if it lights up
의 답변
Displays for this model are very affordable .
의 답변
A flickering display is a backlight issue. But the cause could be the backlight within the display, the ribbon cable & connectors as well as the logic on the logic board.
Using a flashlight can you at least see your desktop when shining the flashlight though the Apple logo in the lid? Also does the external display work? If you don't then its likely the cable and the connectors that have a problem. Often corrosion is to issue.
If you do see the desktop then I would focus your efforts on to the logic board. Double check the connector for corrosion trace the logic to make sure voltage is present. You may have a cold solder joint or the backlight driver and/or the fuse is blown.
의 답변
6에 댓글 더 나타내기
의견 추가하세요
귀하의 답변을 추가하십시오
john dupont 가/이 대단히 고마워 할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 86
