How to unscrew a destroyed screw
Hi guys, really simple i f----g destroyed the screw, its straight up a circle at this point, please what do i do?
좋은 질문 입니까?
좋은 질문 입니까?
wordgg , Because the screw is inset in the bracket, you will probably have to drill it out carefully, with a power drill and metal drill bit of appropriate size till the screw head pops off, then hopefull will be able to grasp what is left with vise grips and turn the remainder out. If possible have a second person hold a vacuum nozzle close to work to catch metal filings. There is also a link below to a guide for stripped screw removal tips. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
해당 답변은 도움이 되었습니까?
Hey man, can you tell me what type of screw is this, i want to replace it, but im not sure what, where etc...
wordgg, click on the link below,click on your model,then on your model #, there will be guides choose the guide that relates to the screw location and the disassembly may have that screw listed in the tear down. good luck.
24 시간 전: 0
7일 전: 1
30일 전: 4
전체 시간: 134
