메인 콘텐츠로 스킵하기
Club Car Golf Cart/클럽카 골프카트 브랜드의 이름을 따서 골프카 또는 클럽카라고 불리는 가스-구동 및 전기 골프 카트 지원.
324 질문 전체 보기
Need help with gas golf cart
I recently bought a golf cart from my farther and law. when he pulled it out of his shed at the golf course it started up backed out and ran good. i started to drive it and it died and then i had to push start did that again and finally the third time i couldnt get it to start. i had to push it with my work beater and it starte up and ran good but wont start on its own where do i start. tried looking up the year but cant find it its a ezgo textron serial no 302633 man code j1983
해당 질문 답변하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
의견 추가하세요
맥북 배터리 수리 키트
기본 가격은 $69.99
Buy Now
맥북 배터리 수리 키트
기본 가격은 $69.99
Buy Now
1개의 답변
가장 유용한 답변
Rodney Baldwin, I believe, Oct=j, year 1983, Start by charging the battery 12.4+ OK and checking/cleaning and retighten all connections. If you charge battery and battery does not hold a charge, the battery is either defective(can be diagnosed usually free of charge at parts store) or you may have a parasitic draw draining battery. when cart is running voltage at battery terminals should read 14.2 volts or better. If battery is good and charged and cart still not cranking, the starter/solenoid/fuse/park switch/ignition/wires/etc. could be faulty and need to be tested and checked. The links below may help in diagnosing your issue. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
http://www.ezgogolfcartguide.com/trouble...
http://www.golflink.com/how_4952_has-spa...
https://axleaddict.com/auto-repair/How-t...
해당 답변은 도움이 되었습니까?
점수 2
의견 추가하세요
귀하의 답변을 추가하십시오
Rodney Baldwin 가/이 대단히 고마워 할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 3
전체 시간: 84
