메인 콘텐츠로 스킵하기
Kenmore Washer agitates and washes just fine but won't spin
If i grab the washer and rock it a few times, then it spins.
답변되었습니다! View the answer 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
의견 추가하세요
맥북 배터리 수리 키트
기본 가격은 $69.99
Buy Now
맥북 배터리 수리 키트
기본 가격은 $69.99
Buy Now
2개의 답변
선택된 해법
Cause 1
Lid Switch Assembly
The lid switch assembly prevents the washer from spinning when the lid is open. If the lid switch assembly fails, the washer will not spin. To determine if the lid switch assembly is defective, use a multimeter to test the lid switch for continuity. If the lid switch does not have continuity, replace it.
Cause 2
Motor Coupling
The motor coupling connects the motor to the washing machine transmission. If the washer is overloaded, the motor coupling will fail in order to protect both the motor and transmission. The motor coupling can also fail due to normal wear. Inspect the motor coupling to determine if it is broken. If the motor coupling is broken, replace it.
Cause 3
Drive Belt
Inspect the drive belt to determine if it is broken or if it is loose on the pulleys. If the drive belt is broken or loose, replace it.
해당 답변은 도움이 되었습니까?
점수 3
댓글:
Check your timer
의 답변
The contacts in timer get bad and wear out.a slight movement of dial could make themjoin together or have contact
의 답변
의견 추가하세요
It could be your motor in some cases.you have a 2 speed motor.one speed say turns clockwise for it to agitate then the other speed would turn counterclockwise for it to spin.you can test the motor by removing it .letting it sit on floor with the wiring still attached then go to yourspin cycle on timer and see if it turns
해당 답변은 도움이 되었습니까?
점수 0
의견 추가하세요
귀하의 답변을 추가하십시오
Jas Holden 가/이 대단히 고마워 할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 32
지난 30일: 108
전체 시간: 848
