Is my new screen the battery drain
i bought an iphone 6 plus with a cracked screen.
i replaced the screen with a OEM screen. Firing it up it work perfect but rapidly baterry drain and sometime locked screen or not going to the next page. Resetting the phone it did not came to life after power down after wiping.
I put a new full battery in it and it worked again. Using it i came to 4 hour use en 48 standby. i was happy.
So i reset the phone again and only in DFU mode i got it started and again the battery was draining. But the strageest thing happend while going through the setting i got this weird screen at registering my finger print. All the text was on thee top of the screen 90% coverd by the cancel bar. All text was written over each line.
Now i thing the screen is my problem for draining and weird behavior , is that possible for a screen thats works further ore perfect ?
Updaten (02-04-17)
UPDATE:
I placed a new screen. and kept the phone running of and on from 100% till 0%
The i I got it running continiously Youtbe app with movies and got 7 hours and 10 minutes with 4% left.
I think that is a fairly good result ? (Bluetooth off, Refresh on backgroud off and handoff off and no sim in it)
좋은 질문 입니까?
댓글 1개
Filters around de LCD/DIGI are all covered in foam , it is hard to not to connect them at once. Around the battery i haven't looked, because the problem was also when not replaced the old battery. When testing the phone for its lifespan. I kept the brightness on half manual and never turning on the screenprotector. The top of the case and mostly on the right side it was hot to very hot.
Bloody !&&* what can go wrong with such a small peace of technology :-)
Roelof 의
