메인 콘텐츠로 스킵하기
The Xbox One S, designed by Microsoft Corporation, was released on August 2016. The Xbox One S is a redesign of the Xbox One.
134 질문 전체 보기
My dog peed on my xbox one S
So far, I know the drive doesn't fully work, won't take the disk inside. It tries also to eject, but that only works if the disk is sticking somewhat out already. Any ideas maybe with rubbing alcohol before I rip this apart? I still love my dog, but %#*@.
해당 질문 답변하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
의견 추가하세요
4개의 답변
가장 유용한 답변
daverelax, Stop charging or powering up your Xbox One S until the liquid damage is addressed correctly, as you could be shorting out components inside the Xbox. You really should take care of the corrosion that is happening inside the device from the pee/water damage as that could be your problem. A tear down link for your device Link #1, disassembly guide will enable you to get inside the Xbox One S to remove the damage/corrosion caused by the liquid. Use the 2nd link as a guide/instruction on how to clean/repair the device from liquid damage. After this you will be able to power on the Xbox One S and see if further damage has to be addressed. Good luck.
Xbox One S Teardown
Electronics Water Damage
해당 답변은 도움이 되었습니까?
점수 4
의견 추가하세요
You can use contact cleaner on the circuit boards. I use it all the time when taking apart laptops.
https://www.amazon.com/Max-Professional-...
해당 답변은 도움이 되었습니까?
점수 0
의견 추가하세요
My dog peed on my xbox and i tried rice but dodnt work when i tried to turn it on it went off like it was on for like 5 seconds then it turned off plz i need help
해당 답변은 도움이 되었습니까?
점수 0
댓글:
Plz help me this chrismas i need a miracle
의 답변
의견 추가하세요
Mine keeps on turning off and on even after I unplugged the touchscreen ribbon. Any suggestions.
해당 답변은 도움이 되었습니까?
점수 0
의견 추가하세요
귀하의 답변을 추가하십시오
daverelax 가/이 대단히 고마워 할 것입니다.
조회 통계:
지난 24시간: 7
지난 7일: 45
지난 30일: 143
전체 시간: 4,626
