Are the displays interchangeable
Hi everybody.
There two MBAs 13", Mid 2012 & mid 2011. One has non working keybord, the other one has a non working display.
I couldnt find an an answer so far, if the displays are interchangeable on those models?!
Even comparing pictures didnt help.
Any ideas? Thx for help.
Kind regards from Krautland
답변되었습니다! View the answer 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
의견 추가하세요
US$100 이상 또는 Pro Tech Toolkit을 포함한 모든 주문의 배송은 무료입니다!
상점 둘러보기
1개의 답변
선택된 해법
2010, 2011 and 2012 assemblies are compatible with each other on MBA 13"
해당 답변은 도움이 되었습니까?
점수 5
댓글:
@reecee: Hello from Krautland & many thanks for your hint. I haven't worked on MBA's so far, so lack of experience. I find it amazing that 3 different models will fit eachother; usually Apple changes tiny bits and pieces within the modelranges, so that e.g. a slightly different socket will throw a spanner in your works.
I will have the chance to check this out by next week & I'll drop you a line.
Kind regards from
Alex deLarge
의 답변
@reecee: Hello from Krautland! I promised to drop you a line! Sorry for being that late, but a very odd flu had kicked into the gutter. All went extremly well! No trouble to interchange the display between the MBA 13 " 2011 & 20112 models. You are a legend in your lunchbox!
Kind regards
Alex deLarge
의 답변
Glad to hear it went well :)
의 답변
의견 추가하세요
귀하의 답변을 추가하십시오
Alexander deLarge 가/이 대단히 고마워 할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 1
전체 시간: 46
