Could the drain pump be clogged?
Put a load of laundry in the machine filled up with water then nothing the 'green senser light is on I drained it manually it drained out very slowly so I was wondering if what's causing the machine not to start is it is plugged it drained all the water except a couple gallons I did the test on it and it did everything but left a couple gallons of water in it
Update (03/30/2017)
Locks look good it filled up with water all the way so I manually took the water out drain the water out and it came out very slowly like something was clocked in there would that stop it from wanting to run the central light stays on and just play Nothing Else and hear a humming sound thank you
좋은 질문 입니까?
댓글 2개
It is door lock assembly but the parts go to take a week to get here is there a way to bypass them so we can do the laundry
Eddie lynn 의
Here's how to by pass it: https://www.youtube.com/watch?v=j8rrZIxA...
mayer 의
