주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Charger broke off in iPad
My mom has a 4th gerneration iPad, model A1458. It has an electric wall charger with an end similar to the iPhone 6. While her iPad was charging, it fell from her chair to the floor, and the charger that is inserted into the iPad to charge broke in half, leaving half in the iPad with no way to get it out.
Any suggestions?
Thanks!
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개
I just used tweezers for mine that broke off in it.. took me a few tries, but it came out!
댓글 달기
답변 2개
선택된 해법
The plug does "snap" in place so it will require some light force to remove. Try some tweezers or fine point long-nose pliers. You may also try to pry it out (gently) with something pointy, working one side at a time.
Be careful because you don't want to do any unnecessary damage to the housing, port or glass.
If you don't have the proper tools, consider going to your local shop and they may do it for a low fee.
이 답변이 도움이 되었나요?
점수 2
댓글 1개:
This happened to me today. I used a small kitchen paring knife and pried at one end until it loosened and fell out.
댓글 달기
I would try and pry it out carefully with pointed tweezers :
https://www.amazon.com/URBEST-Compact-St...
try to keep the tweezers in the center of the port hold when prying the piece out because there are pins on the side wall of the port that can easily be damaged.
There are shops that do this type of thing for free. I do at my shop. I would call around and ask a few different shops.
이 답변이 도움이 되었나요?
점수 2
댓글 1개:
thank you for the link... this is so helpful. never had this happen before!
댓글 달기
답변을 추가하세요
tshortgobucks 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 10
지난 30일: 60
전체 시간: 19,947
