메인 콘텐츠로 스킵하기
Apple iPhone 5s는 2013년 9월 10일에 발표되었습니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 16, 32, 또는 64GB / 은색, 금색 및 스페이스 그레이.
3886 질문 전체 보기
Frozen on startup without home buttom
Hello, yesterday my phone battery died and I tried to just charge it but then I come to the moment where the apple logo shows up but nothing more happens, I have drained the battery more than 7 times but I wont get further then the apple logo. My home buttom is broken so I cant do the forced restet and tried to look at where you "erased your find your phone" but still wont work. Apple says they have to switch the whole buttom to make it work but is there anybody else outhere that knows what I can do?
해당 질문 답변하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
의견 추가하세요
맥북 배터리 수리 키트
기본 가격은 $69.99
Buy Now
맥북 배터리 수리 키트
기본 가격은 $69.99
Buy Now
1개의 답변
가장 유용한 답변
Did you change the battery because the phone went flat and you didn't charge it?
If yes check charging port for debris blockage and use some tool carefully to clean it out if it's blocked.
If it's clean and plugs in properly then it's most likely a U2 Tristar charging ic chip gone on the logic board which goes bad if a car charger was used with a cheap aftermarket lightning cable (non-MFI certified).
You can test chip by unplugging battery, plugging it back in then plug the charging cable in. If it turns on itself with apple logo then chip is probably fine. If it doesn't turn on itself and you need to hold power button to turn it on then its probably the chip.
해당 답변은 도움이 되었습니까?
점수 1
의견 추가하세요
귀하의 답변을 추가하십시오
lundback.sebastian 가/이 대단히 고마워 할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 29
