Batteries interchangeable between series?
Are Apple watch batteries interchangeable between all the different series? Say I need to replace a 38mm apple watch battery (original), can I use a 38mm battery for series 1 in the original?
좋은 질문 입니까?
좋은 질문 입니까?
Sorry no, The original Apple watch uses a different connector system for most everything and that includes the battery. See for your self here:
Original Battery
Series 1 & 2 Battery
해당 답변은 도움이 되었습니까?
**Editing to say that I am 100% sure you can swap batteries between the First Gen and Series 1 Apple watches because I’ve successfully done it countless times.**
I'm pretty confident that you can use a battery from a Series 1 Watch in an Original Apple Watch. The internals between the Original and the newer Series 1 are almost identical. (The processor was about the only change.) In fact, if you order a replacement battery from ifixit.com, the batteries are listed as being compatible with either Watch. Also, the details about the used OEM batteries listing even says that they are taken from either an Original or a Series 1 Watch.
Apple Watch (38 mm, Original & Series 1) Battery
[연계 제품이 누락 또는 비활성화 됨: IF308-010]
Series 2 is different though and cannot be used in the earlier models.
해당 답변은 도움이 되었습니까?
24 시간 전: 2
7일 전: 3
30일 전: 33
전체 시간: 2,236
댓글 2개
Can I use the Apple Watch battery from a series 1 for a series 2
Darnell Morgan 의
Hi,
Is the apple watch series 1 and series 2 batteries interchangeable ?
Mishalin 의
