주요 콘텐츠로 건너뛰기
7.9 inch display / Model A1432 / Available in black or white / Announced October 23rd, 2012 / 16, 32, or 64 GB capacity
220 질문 전체 보기
Why do the Colors invert after replacing the LCD Screen?
I replaced an LCD on an iPad mini 1st gen. When you press on the screen toward the bottom, it switches to inverted colors. It also keeps prompting Siri. I believe it might need a new ribbon cable and home button. Any suggestions? Thank you.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
tripple-clicking your home button will invert the colours, and holding it will activate siri.
This could be a short in your flex, on the connector, or a mechanical pinch of the button.
-i would suggest removing the new screen, but keeping it plugged in. test the button with the screen apart from the frame. if this fixes the issue, it is a mechanical pinch, and you need to sort out how it fits in your frame.
-be sure you have taped the digitizer circuit across the bottom with electrical or Kapton Tape.
-make sure the home button slides nicely between the LCD And the Frame.
your home flex ribbon may be shorted, in which cas you will need to re-replace it
You could have the connector to the Motherboard having a loose pin. in which case you will either need to realign, or replace that connector.
해당 답변은 도움이 되었습니까?
점수 1
댓글 2개:
Thank you so much! I didn't know about taping the cable across the bottom, but it makes total sense.
pleasure to be of assistance. took my shop a few ipads to figure that out
댓글 달기
귀하의 답변을 추가하세요
Nathan Davenport 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 6
전체 시간: 458
