메인 콘텐츠로 스킵하기
How to remove or fix spots 'dots' on my Panasonic LED TV?
Hi there is some kind of spots or dots on my Panasonic TV that are hard to see on something colorful or black but you can see them clearly in brights and white areas of screen, and dots is in some kind of a pattern like 3 dots down and 8 dots in a row with the same spacing
Is there any way to get rid of them or maybe you can help me fix it ?
Thanks for your answers and thanks for help ;)
Update (04/04/2017)
There is some photos
해당 질문 답변하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
의견 추가하세요
맥북 배터리 수리 키트
기본 가격은 $69.99
Buy Now
맥북 배터리 수리 키트
기본 가격은 $69.99
Buy Now
1개의 답변
가장 유용한 답변
Arturas Vaitekun it will be helpful if you can post some images of what you see on your screen. Post some images with your question by using this guide for that. It will allow us to see what you see. "pattern like 3 dots down and 8 dots in a row with the same spacing" this could be caused by bad pixels (can't fix that because it is an error in the panel) or it could be bad LED backlight strips which I believe is the issue with your TV. Once you post some images we most likely can give you a definite answer. Right now, without seeing it, it is all speculation.
Update (04/04/2017)
Thanks for the pictures. Yes those are definitely your backlight strips. Let me see if those can be had separately. In the meantime check out this video to see how to do it.
해당 답변은 도움이 되었습니까?
점수 1
의견 추가하세요
귀하의 답변을 추가하십시오
Arturas Vaitekun 가/이 대단히 고마워 할 것입니다.
조회 통계:
지난 24시간: 6
지난 7일: 100
지난 30일: 449
전체 시간: 5,994
