Can I use a ceramic fuse in place of a glass one?
I have a cigarette lighter adapter which is part of my inverter that has a blown fuse. The one in it was a 15A at 250V Glass Fuse but the one that i can find at my local radioshack is 15A 250V CERAMIC Fuse. Can i use the ceramic fuse in place of the glass one or will it cause damage?
Also there is a 15A 125V Glass fuse and the power that is being used in only 12v so could I use that instead?
답변되었습니다! View the answer 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
의견 추가하세요
US$100 이상 또는 Pro Tech Toolkit을 포함한 모든 주문의 배송은 무료입니다!
상점 둘러보기
1개의 답변
선택된 해법
I would stick to the same fuse type. Ceramic fuses will "blow" much more slowly and could cause lots of upstream/downstream damage if the rest of the circuit isn't expecting extra current.
You may want to do some reading.
해당 답변은 도움이 되었습니까?
점수 7
댓글:
Well you half answered my question, the other part was Also there is a 15A 125V Glass fuse and the power that is being used in only 12v so could I use that instead?
의 답변
Missed that, sorry. Yes you can use a 125V fuse for your 12V system. As long as the fuse is rated for higher voltage, you are okay.
의 답변
I tested it and it worked. with the ceramic one. There is also a 10A fuse from the power going to the circuit, a 15A fuse which is in the main fuse box attached to the line i tapped off of and then a 40A fuse at the inverter, so there is 4 fuses in the entire circuit I made so there isnt any worries i dont think
의 답변
의견 추가하세요
귀하의 답변을 추가하십시오
Cameron 가/이 대단히 고마워 할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 12
지난 30일: 63
전체 시간: 960
