Nothing Being Displayed on Caller ID Screen
I'm looking for a way to fix this phone. The sound is working and it rings when called but nothing visibly comes up on the display screen.
해당 질문 답변하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
의견 추가하세요
US$100 이상 또는 Pro Tech Toolkit을 포함한 모든 주문의 배송은 무료입니다!
상점 둘러보기
1개의 답변
가장 유용한 답변
Is the base unit screen showing anything? Try pulling the base units battery and/or replacing it also check the power cord & transformer it could be dead
Does the cordless unit have a screen? If it does is it working?
해당 답변은 도움이 되었습니까?
점수 2
댓글:
Yes the base is working. And it is fully charged. There are 4 handsets and I think this one got wet and the screen no longer displays anything. Not sure if it can be repaired or need new one.
의 답변
Sorry to say not much you can do here.
You could try opening the handset to see if you can spy any corrosion around the display screens connector. Using some distilled water and cotton swabs (Q-Tips) try to clean things up.
Otherwise, you'll need a new unit if you really need a fourth handset.
의 답변
의견 추가하세요
귀하의 답변을 추가하십시오
Lynne 가/이 대단히 고마워 할 것입니다.
조회 통계:
지난 24시간: 4
지난 7일: 25
지난 30일: 93
전체 시간: 3,006
