Will not drain, spin or operate on any cycle
I already tried power cycling but that was no help. Also tried spin/drain setting but that was no help either.
좋은 질문 입니까?
좋은 질문 입니까?
Lid switch
If the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it.
Some machines have a special lid-switch fuse near the lid switch, inside the control panel. If this fuse blows, the unit won't fill with water until you replace the fuse.
Do you get any error codes?
Here's the part: http://www.repairclinic.com/PartDetail/L...
Right below the part is a video on how to install it.
해당 답변은 도움이 되었습니까?
That was the problem on mine +
Yes error code 03
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 1,202
댓글 3개
Does it power on? I'm guess there's a blown fuse.
rab777hp 의
It has power and will turn on
Rob 의
Mine too same thing
mommabear2015 의
