No display image after fall
I dropped my MacBook Pro. It fell half a meter on the top side (it was closed).
- Plugged in to an external monitor works ok
- No light in the apple logo on the back of the display
- Tried to see some image on the display by using a flashlight on the apple logo in the back but couldn´t see anything.
- Webcam works ok
I´m willing to replace the entire display assembly, but I´m unsure if there is another component that might the culprit (like the logic board or some cable). Can you recommend tests to try to isolate the cause?
Thanks!
좋은 질문 입니까?
댓글 3개
First things first I would always try disconnecting the Display form the Logic Board and then connecting it back in and make a solid connection. If this doesn't work then I would go with the Display being needed.
Daniel Mason 의
You should open up the unit and reseat the display cable, if that doesn't work I would recommend you remove the display, remove clutch cover on display and inspect both ends of LVDS cable. Buying a $400 display on a hunch seems risky.
Forza Vale 의
You both were right, reconnecting the LCD cable did the trick. Thank you!
Fernando Martinez Herrera 의
