The M.2 256GB SSD in this MBA W/Red Sensors Won't Boot or Mount
Mid-2012 Macbook Air 11.6" A1406 256GB M.2...
I removed the SSD from an unknown-condition MBA 11.6", Mid-2012. It boots to a question mark, so I pulled the SSD and it has pale-red moisture sensors. I assume it's gotten wet. Would liquid kill this SSD so that it wouldn't even show up at all in a drive enclosure plugged into another Mac?
I plugged it in, unplugged, then loaded Disk Utility wherein there was no SSD to see. One odd thing is how long Disk Utility took to load. So maybe it sees _something_, but can't load it?
I also tried Drive Genius 4: NADA!
I removed it from the enclosure, then cleaned it using 99.9% Tech Grade Isopropyl Alcohol. Dried it then repeated the exercise, again, NADA.
I assume this drive is dead?
Anything else to do other than add it to my Xmas tree?
Thanks!
JoeL
Atlanta
좋은 질문 입니까?
Did you put it in an OWC Envoy? The is a red dot on the sticks that is not an LSI.
mayer 의
Sounds like a dead SSD. I had the same symptoms with an SSD from a water damaged Macbook Pro. It had corrosion too, changed the affected parts, still no work.
Alex 의
