@bo1 the 5 blink error code can have quite a few different causes. Ranging from the T-con board to the panel and few things in between. If you have the original TV remote than try to see if this will work on your set:
1. In standby mode, press the following buttons on the Sony remote:
DISPLAY....5....VOL(-)....TV POWER
2. On the left side are the blink codes. On the right hand side is the error count.
3. Under 005, you'll see three listings... TCON, HFR, and P-ID (panel).
4. Let us know what errors your set shows.
If that does not work on your set, then you will have to remove the back of your TV and check the boards. Try to rule out/in the T-con board as faulty. Disconnect the LVDS cable to the T-CON board, the cable between the Main board and the T-CON board, and see if the error code will change. Let us know what the result is.
댓글 32개
Had the same problem replaced Pico fuse on Power Supply fixed problem. Fuse is located near top left closer to connector plug . Fuse is & amps marked as L7.
Bobby Mays 의
Had the same problem replaced Pico fuse on Power Supply fixed problem. Fuse is located near top left closer to connector plug . Fuse is 7 amps marked as L7.
Bobby Mays 의
Hello,
I have a Sony Bravia 40 inch smart LED, model KDL40W652D. When I switch it on, it switches one for few seconds, and then the screen blacks out followed by 5 times red light blinks.
Is there a way to get this fixed… thanks much for your help.
Regards,
Sid
sid 의
yes me too facing the same problem
contacted sony customer care and technician visited checked and told its a Tcon board problem
Sb Basu 의
my sony bravia model KDL-50W800D
Sb Basu 의
댓글 27개 더보기
