주요 콘텐츠로 건너뛰기
Repair guides and support for C/K pickup trucks sold by General Motors under the GMC brand, including the GMC Sierra.
50 질문 전체 보기
will not turn over, got lights radio,etc
1992 gmc serria pickup turn key on got lights, etc. will not turn over
답변되었습니다! View the answer 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글:
Do you get a clicking from the solenoid?
의 답변
의견 추가하세요
iPhone X Fix Kits
Warranty up? No worries, we’ve got the fix.
지금 장보기
iPhone X Fix Kits
지금 장보기
3개의 답변
선택된 해법
@jj253 , Ernestine, Even though the lights do come on, the battery could be low or bad connections, check for 12.2v+ at the battery,check connections on battery and follow them to their other end to ensure not corroded or loose. If need be try boosting. If truck starts, problem will be weak battery or bad connections.
When running if the battery is not showing 13.8+v, the alternator may be weak also.
If battery, connections, fuses/relays all look good, with foot on the brake, if automatic, shift out of park and try starting truck in neutral and other gears, this will maybe tell us if the safety neutral switch is out of adjustment, but could still be faulty, just as on a standard tranny the out of adj. or faulty clutch switch can cause this issue.
Now if able to access the starter give it a couple raps with a heavy object(hammer/metal bar) careful not to hit solenoid. After giving starter a couple good raps, try starting if it starts, the starter is sticking and faulty.
Now if the above had no effect and you can access the 2 large solenoid terminals and safely cross them out with a screw driver and truck still will not crank then the solenoid/starter are faulty.
Some of the auto parts suppliers offer free battery/starter/alternator testing, like Pepboys, Nappa, Advanced auto parts,etc and some of the guys are very knowledgeable and may have seen the issue often and put you on the right track. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
해당 답변은 도움이 되었습니까?
점수 1
의견 추가하세요
가장 유용한 답변
@jj253 "will not turn over" should prompt you to check the starter first. Start with this trouble shooting and let us know what you find.
Update (04/09/2017)
@jj253 if you are more of a reader, here is the part that deals with the starter GM Starter. It will explain the trouble shooting as well as the repair.
해당 답변은 도움이 되었습니까?
점수 1
댓글:
@oldturkey03 I think the problem he is facing is that it cranks, but will not turn over. If its not cranking at all, its the started but if it cranks but don't start its probably the fuel pump.
의 답변
의견 추가하세요
https://www.youtube.com/watch?v=mDIlwbx0... That might be the issue. If it isnt please give more details.
해당 답변은 도움이 되었습니까?
점수 0
의견 추가하세요
귀하의 답변을 추가하십시오
ernestine gilmore 가/이 대단히 고마워 할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 100
