주요 콘텐츠로 건너뛰기
All-in-one PC, HD, PC/TV, 22' widescreen, Blu-ray drive, wireless LAN, 500GB HD, LT line
7 질문 전체 보기
My screen color is weird how to fix it?
I was using this computer for a year now and there is nothing wrong with it.
But recently i had a problem, with the screen color.
[[IMG]http://i68.tinypic.com/b4ere0.jpg[/IMG]] or http://i68.tinypic.com/b4ere0.jpg
[[IMG]http://i68.tinypic.com/wqjgy.jpg[/IMG]] or http://i68.tinypic.com/wqjgy.jpg
This is what it looks like. Click on the click to view the image. This happens as the window is loading too.
Update (04/10/2017)
This is not a touch screen computer. Secondly I was playing a game when thie screen color was weird. I can assure you that it not broken screen look at this image
http://i63.tinypic.com/15cm1bs.jpg
Copy it and past it to see the image
I have found this while I was looking at the screen setting
I can't put another screen to check as there is no place for this All-in-one pc. It Vaio Sony computer if you need that. Ask me anything else and I can answer it for you.
I have 2 operating system and this problem occurs on both. If this help I have tried and reinstall the graphic drive but nothing has changed.
Be waiting for your answer
Update (04/13/2017)
This is not an answer but this is from me so that everyone can read it and can comment on it easier.
So i have read all of your comments and thanks to you all to help me on this.
Firstly i will tell you about my computer.
It Sony Vaio All in one PC which means it cant connect to another computer as my computer doesn't have any other plugs for other screens
It non touch screen.
The problem happened as i was playing on a game. But there is a button on top of the screen that turns the screen off i clicked once and the screen came back to normal then back to this weird colors.
I have tried going screen shot then looking at it from another computer but seemed fine. The first photos where from screen shot.
This is from safe mode
[<a href="http://tinypic.com?ref=34dsgpg" target="_blank"><img src="http://i65.tinypic.com/34dsgpg.jpg" border="0" alt="Image and video hosting by TinyPic"></a>]
or
[[IMG]http://i65.tinypic.com/34dsgpg.jpg[/IMG]]
[<a href="http://tinypic.com?ref=10riwl4" target="_blank"><img src="http://i67.tinypic.com/10riwl4.jpg" border="0" alt="Image and video hosting by TinyPic"></a>]
or
[[IMG]http://i67.tinypic.com/10riwl4.jpg[/IMG]]
[<a href="http://tinypic.com?ref=29z4z60" target="_blank"><img src="http://i66.tinypic.com/29z4z60.jpg" border="0" alt="Image and video hosting by TinyPic"></a>]
or
[[IMG]http://i66.tinypic.com/29z4z60.jpg[/IMG]]
This is what look like when it has blank screen
[<a href="http://tinypic.com?ref=2uyrfyp" target="_blank"><img src="http://i65.tinypic.com/2uyrfyp.jpg" border="0" alt="Image and video hosting by TinyPic"></a>]
or
[[IMG]http://i65.tinypic.com/2uyrfyp.jpg[/IMG]]
By the way there isn't any buttons on the screen or the computer that will change the colors or the brightness.
So hopefully this information might help you guys answering my question.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 9개
Looks fine to me. Whats wrong?
@thegamelord sorry to hear about your computer. Can you provide more detail for me. 1 is this the touch screen model? 2 from the pictures provided it would appear as if someone pressed to hard and possibly cracked the LCD. When did this issue start? And what were you doing ? Also it the color always distorted on every screen?
Thanks
Chris Dixon
This isnt an answer but more of a comment
The colors for Firefox icon looked correct, the back ground was weird. Do you have pictures with a background that is not so busy? The reason I point out that the Firefox icon looks correct is that has has reds, blues and yellows and the shading looked good.
My apologies I posted in the wrong section earlier. Did you install any updates recently ? Also look into seeing if VGA mode is enabled
댓글 4개 더보기
댓글 달기
답변 1개
가장 유용한 답변
It is hard to say what is going on with the pictures, what it looks like is the brightness/contrast is different in some parts of the display. Open a blank text document and see if the brightness is the same over the whole area or if there are bright spots or dull spots. Try adjusting contrast and brightness and then check the color saturation by changing the background of the blank text to be all red, then all blue and then all yellow. Try adjusting the colors if they are off hue.
Use the controls on the display to make adjustments. The problem could be either the display or the GPU if you are still having weird colors.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
귀하의 답변을 추가하세요
Abody ale 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 3
7일 전: 4
30일 전: 23
전체 시간: 2,993
