주요 콘텐츠로 건너뛰기
The Dyson AM07 is a bladeless tower fan released in 2014. The AM07 uses "Air Multiplier" technology to create a smooth stream of air without using visible blades.
19 질문 전체 보기
fan not oscillating back and forth
What's wrong and how do I fix it?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 1개
I have the problem too, it is not oscillating.
댓글 달기
답변 1개
선택된 답변
mkoch, If it is new, did you remove the tape, from the lower base body split section, if not remove before turning on any more or damage to internal gear could occur. Recheck that the fan is still assembled correctly and locked in correct position. Install new batteries in remote and try. If all looks good and still under warranty return for repair/replacement/refund as there may internal damage to oscillating gear. See below links, your manual and Dyson support site.
Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
https://www.manualslib.com/manual/888752...
https://www.dyson.com/support/am02/am02-...
해당 답변은 도움이 되었습니까?
점수 7
댓글 2개:
So simple, duh, I forgot the tape. But it doesn’t show that in the setup instructions.
I need help in opening the remote. I've had three people look @ this remote. Pls help!!!!!!!!!!!!
댓글 달기
귀하의 답변을 추가하세요
mkoch 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 8
7일 전: 69
30일 전: 220
전체 시간: 41,235
