주요 콘텐츠로 건너뛰기
Repair information and troubleshooting for Craftsman-brand riding lawnmowers.
545 질문 전체 보기
starter solenoid wiring diagram from battery to solenoid
Craftsman Riding Mower model27011 i need to know how the wiring diagram from battery to solenoid to starter is configured
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 9
댓글 달기
답변 3개
가장 유용한 답변
@lawnboy707 verify your complete model number for us. This diagram should work for your mower.
해당 답변은 도움이 되었습니까?
점수 3
댓글 2개:
I want to know to
@randystarcher you would like to know what :-)? Have you checked the above posted diagram?
댓글 달기
@lawnboy707, John, Below you will find the manual and pic's/schematic of how wire's are hooked for starting system, for Model #502270111 CRAFTSMAN Lawn, Riding Mower Rear Engine. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
http://www.searspartsdirect.com/model-nu...
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
here is the wiring diagram i found at https://www.searspartsdirect.com/model-n...
해당 답변은 도움이 되었습니까?
점수 1
댓글 2개:
In the diagram there are the numbers "1-26". It would be helpful to have the key along with the diagram to help identify what each number correlates to. I.E. number 3 identifies the anchor bolt for the hot wire to the positive battery terminal
@Michael Dodson
If you click on the link provided in the answer above your comment you will get the Sears webpage where it came from.
Under the diagram on the page is a list of the part numbers as shown in the diagram and if you then click on the relevant part i.e. part #1 = Sensor 91031 you will get the part description etc.
Search online using the required part number to find suppliers that suit you best e.g. this supplier is cheaper than Sears (although shipping may be a factor to be aware of depending on your location)
댓글 달기
귀하의 답변을 추가하세요
john 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 38
7일 전: 228
30일 전: 1,023
전체 시간: 77,864
