Repair guides and support information for EVGA tablets.
1067 질문 전체 보기
Tablet saying high voltage
I was charging my tablet and so after, I unplugged it. The tablet came on then it blank out. But before that it said high voltage. When you charge it the light be orange but now the light is blue.
해당 질문 답변하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
의견 추가하세요
US$100 이상 또는 Pro Tech Toolkit을 포함한 모든 주문의 배송은 무료입니다!
상점 둘러보기
1개의 답변
What is your tablet model, and do you have a multi meter/voltmeter?
If you do have a multi-meter or voltmeter, you must test the voltage on the battery. Unplug the battery if you can, then contact the red pole to the red wire, and the black to the black. If the voltage does not match what it says on the the battery (battery probably says 3.7v) replace the battery. Also, get a new USB wall adapter as that is likely the source of the problem. Get a good one like Anker or Aukey brand.
Do not try charging it! If the voltage is wrong, you may break your tablet even more! There is also a chance of exploding like a Note 7.
Hope this helps!
해당 답변은 도움이 되었습니까?
점수 0
의견 추가하세요
귀하의 답변을 추가하십시오
sharoncody50 가/이 대단히 고마워 할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 4
전체 시간: 94
