메인 콘텐츠로 스킵하기
Apple iPhone 5s는 2013년 9월 10일에 발표되었습니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 16, 32, 또는 64GB / 은색, 금색 및 스페이스 그레이.
3883 질문 전체 보기
Top speaker problem in my phone
When i receive call i can't listen them properly. I have just replace screen 4 month ago and when i tried for video call and set up loud speaker another person in call isn't able to listen my voice but they can listen to me when i use headphone
답변되었습니다! View the answer 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
의견 추가하세요
1개의 답변
선택된 해법
Look at the hole in your screen, where there is a small piece of black mesh.
Behind that mesh there are the ear-speaker from which you listen when phone is near to your ear AND the mic from which you talk when in loudspeaker mode.
If this issue happened some time after your replaced the screen, and the sound became lower and lower with time, there is probably some dirt on the mesh. Brush it clean with a toothbrush dipped in iso propyl alcohol (90%+) or even scrap with a needle and then punch 3-4 tiny holes.
If this happened immediately after you replaced the screen and you can't hear any sound at all, then that cable is damaged; or you did not click it in place properly; or there is a small piece of film covering the hole that you failed to remove before transferring the cable.
해당 답변은 도움이 되었습니까?
점수 3
의견 추가하세요
귀하의 답변을 추가하십시오
Shyam 가/이 대단히 고마워 할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 24
