메인 콘텐츠로 스킵하기
The Nintendo 2DS is a handheld gaming device developed as an entry level version of the Nintendo 3DS with nearly identical hardware, but without the 3D upper screen function.
133 질문 전체 보기
SD Card Stuck In Write-Protection (Console Problem)
Hello,
i am having a problem with the console saying the SD card is stuck in write-protection. i can tell you for a fact, the card is not. the slide is at the top and have even tried 2 other SD cards. The other SD cards i have also work fine in another 2DS i have tried.
are there any suggestions how how to fix it? i updated the console and formatted it just to see if that would fix it.
Thanks
해당 질문 답변하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
의견 추가하세요
1개의 답변
가장 유용한 답변
Try to open up and clean the contact pins, they could be dirty and shorting something out.
해당 답변은 도움이 되었습니까?
점수 3
댓글:
Thanks for the reply, i gave it a shot but to no prevail. nothing is screaming out at me that there is anything wrong visually
의 답변
What about the 2 smaller pins to the side?
의 답변
they appear to be fine, not touching each other
의 답변
What about cleaning around the connector? Also has it ever been water damaged?
의 답변
yeah ive cleaned it. it was all clean already but gave a clean as best i could just in case. there is no liquid inside. no visible sign of water damage
의 답변
의견 추가하세요
귀하의 답변을 추가하십시오
James 가/이 대단히 고마워 할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 16
지난 30일: 83
전체 시간: 1,788
