주요 콘텐츠로 건너뛰기
How to cancel "RESTORE"
Accidentally held the home key and the menu key at the same time. Now my iPod is in the restore mode.
Is there any trick to reverse or cancel this? Otherwise I will have to restore it and everything will be lost. OUCH!
Thanks for any suggestions.
Norm
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
@musichouse ,Norman, I do not own this device, did a search and found this info at the link below, perhaps it will shut down your iPod and get you out of your predicament.
If your iPod appears to have crashed or frozen and you need to force it to restart, simply hold down the 'menu' and 'play' buttons simultaneously for about 5 seconds. The iPod should quit and reboot.
Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
http://www.benhuson.co.uk/2005/03/02/res...
해당 답변은 도움이 되었습니까?
점수 1
댓글 2개:
Thanks for the effort but it still doesn't work. Guess I'll just have to loose my data.
@musichouse ,Norman, Sorry it did not work, I take it that you have tried to shut the device off and just not successful. You could try removing the battery which is not the simplest and I am not positive it would work either. I will post link below if you would like to try. Your question is also still posted and perhaps some one else may have more knowledge. @jimfixer would you have any Knowledge of Norman"s issue above,Thanks! I truly hope you have good luck.
iPod Classic Battery Replacement
댓글 달기
귀하의 답변을 추가하세요
Norman Ernst 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 76
