Why the computer is on but the screen is completely black
I upgrade my Windows Vista to Windows 7 Home Premium, before that, I run Windows 7 Upgrade Adviser, it said I can run Windows 7 Home Premium and Windows 7 Ultimate. After upgrading, the computer work fine, I made a system restore just in case. After turning off the computer, next day I turned it on and the screen is completely off, the fan is on, the computer is on but the screen is blank, everything is plugged in but, pls help me
좋은 질문 입니까?
댓글 10개
Try unplugging the cable and plugging it back in at both ends.
George A. 의
the monitor cable or the pc box (the power cord of the pc box)
nghiagmt 의
The video cable. What model is your PC?
George A. 의
Hi,
Is the monitor powered on?
Can you access the monitor menu options by pressing the menu button on the monitor? (You don't give a make and model number for either the PC or the monitor, this would really help us to help you!)
If you can see menu options on the monitor have you tried starting the PC in 'safe mode' to see if there is a display?
Do you see the PC's 'splash screen' , screen that shows the PC maker's name before it boots into Windows?
Can you connect another monitor to the PC to prove whether the problem is the monitor or the PC?
What have you tried to do to get a display on the monitor?
jayeff 의
Yes, the monitor is powered on
No, I can't access the monitor menu when I press "menu" button. Model number of the monitor I think it is HP S1932 Monitor, PC Model could be HP dx2700 microtower base DT PC
The display is blank when I turn on, so I can't access "safe mode"
No, the display is complete blank, completely nothing happened when I turn on the PC
No, I didn't, but I think I will try
Don't know, it was my dad's computer, everything was set before he gave it to me, but maybe he just plug all the cables for the monitor
nghiagmt 의
댓글 5개 더보기
