Battery loses full charge in about 90 minutes - new issue
I've got a 3GS running 4.2.1 and it's about 1 year old. I've always had a Mophie Juice Pack on it, and would usually go through both the internal battery and the external in about 16 hours of pretty heavy use, as I would expect...
Then 2 days ago the phone has decided to burn through the internal battery in about 90 minutes, and takes the external battery about the same time to deplete as well. The phone is always warm, and takes about 4 - 5 hours to charge back up.
I've tried restarting, restoring, and removing all apps but the base ones - but nothing has helped.
Is it possible for a battery to die from one day to the next (literally)? Should I replace the battery, or something more?
좋은 질문 입니까?
댓글 2개
I'm having the same battery issue, and getting a new battery doesn't help. Mine seems to be lasting longer than yours, but it's draining WAY faster than it used to. Mine, though, charges back up pretty quickly, not slowly. Mine also runs warmer than it used to.
Mark 의
Similar situation with my 3GS. Have replaced the battery but after charging up as normal, charge is lost in less than a day. Battery also gets hot when charging up
David Anning 의
