주요 콘텐츠로 건너뛰기
The JBL Charge was released in 2012. It features Bluetooth and 3.5mm audio for a wide range of inputs. A high-capacity 6000mAh battery provides several hours of entertainment and can charge other devices with its built-in USB port. Available in Black, Green, Gray, and Blue.
28 질문 전체 보기
Will pair with some devices but not all.
My jbl charge will not pair with all my devices
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
To truly understand the problem, and how to fix it, you should try and provide more information. Such as: which model of JBL Charge do you have? What devices are you having problems pairing to the speaker?
Moving on however, if some of the devices are not pairing, it could be a couple of things. Maybe the drivers are not updated? Good site on how to update
Also, you can try restarting the other devices, or even the speaker, to see if that would help with the connection.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
Kneebee 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 41
